sudden camera blur
buggy
I have a scene in which I have two main subjects. At some point one of these objects starts to move off the scene. I rendered the scene out to individual frames.
It starts moving and after several frames everything in the scene suddenly goes blurry (not just the moving object). The camera is static and its settings aren't animated.
If I render one of these blurred frames using the OctaneRender Viewport it comes out sharp but if I hit render on a single frame it is blurry.
Any ideas?
Thank you,
buggy
Win 8.1 | 2x GTX780 6GB RAM + 1x GTX 660 | Intel i7 | 16GB RAM | 3DS Max 2011
Karba
buggy wrote:I have a scene in which I have two main subjects. At some point one of these objects starts to move off the scene. I rendered the scene out to individual frames.
Any ideas?
Thank you,
buggy
Do you use subframe motionblur?
Please show your problem renders.
buggy
The problem seems to have gone away on its own. To test it with something simpler, I hid the objects in the scene and placed a simple box in the scene. When I rendered it there was no blurring. I then hit undo a few times to bring back my objects and then hid the box. Now it renders the scene like normal.
I am using an Octane Camera. I'm not aware of any motion blur turned on (also it was blurring everything, not just the moving object).
Where do I find the sub-frame motion blur setting?
Thank you.
Karba
buggy wrote:The problem seems to have gone away on its own. To test it with something simpler, I hid the objects in the scene and placed a simple box in the scene. When I rendered it there was no blurring. I then hit undo a few times to bring back my objects and then hid the box. Now it renders the scene like normal.
Thank you.
You can find it only in standart camera at the moment.
suvakas
The exact same thing has happened to me too.
I used standard camera and standard Multi-pass motion blur effect.
I guess Octane is not 100% compatible with it?
Suv
Return to “Autodesk 3Ds Max”
