That is rendered using the "render" button, not the Octane viewport, but it has happened several times now with the Octane viewport and the render route. The saved EXR file looks like that too, so it's not just a viewport problem with the framebuffer.
It should look more like this (super lo-res render, but you can see the brightness as it should be).
Both renders are still actually clamped (no >1 values to be found in Photoshop, but the first one looks really messed up too. Is there a bug going on here? Both are rendered with PMC, nothing fancy.
