Tutor wrote:Notiusweb wrote:...
BTW, Tutor, do you see a less smooth maneuvering of a scene when Post Processing is enabled, for a high res scene (ie 1080p).
Only to run your test file at your request have I used V3. So no because I haven't had a basis to judge it at all.
Tutor. Actually, it exists in V2 as well, only less pronounced.
So, if you ran my red car file at a res of 3840 x 2160, on V2, and try maneuvering the scene with the mouse, I am curious if you will see a difference in maneuvering speed/choppiness when Post Processing is enabled vs not enabled.
I am expecting you will, as it happens to me with just the Titan X at 16x. But if you do not, man, there is definitely something that my PC may need (i.e. a CPU upgrade, etc)
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
