OctaneRender™ Standalone 2.01 - updated
Dmi3ryd
Any ideas?
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
ROUBAL
Hi, As there is only one object,I think that you just imported it at the center of the 3D world. It is a critical point, especially with planes. Just try to move it just few millimeters up or down...
roeland
enricocerica wrote:Some suggestions,
1.Is it planed to add an option on the object layer to allow an object to not receive light from any source ?
This is really needed to be able to add a back plane and to avoid over lit areas.
2.When having very messy node graphs it's quite difficult to localize the object on which a selected material is plugged. A key press like the dot in Blender which automatically displays the graph area with the selected material pin would really avoid looking all around to find it ;)
Edit :
3.Forgot this, is it possible to enable a placement to be shared by several objects, for instance I use characters billboards and this would be really helpful to be able to rotate them all together to match the camera.
1. It's not on our road map. What are you trying to achieve? In a lot of scenes if an object doesn't receive direct light it will be very dark or almost black. If you need an object with a constant colour independent of illumination, use a texture emitter with low power on a black diffuse material.
2. You can right-click in the node inspector on the node icon left of the node name, and choose "Show in graph editor", But there is no hot key.
3. You can hook up one transform node to multiple placement nodes. For billboards however you will need slightly different rotations depending on where they are in the scene.
Roeland
abstrax
ROUBAL wrote:Hi, I am experimenting with 2.01. Great work guys ! Thank you for the wonderfull new features.
Well, I have seen two weird things. As I have not had time to read everything on the forum these past days, I don't know if it has been already signalled :
:arrow: No textures limit is great, but I have noticed something weird in the textures count :
My current project uses :
1 LDR RGB JPG for environment.
1 LDR RGB BMP for diffuse Color.
1 LDR RGB BMP (declared as Greyscale in Octane) for Bump.
1 LDR RGBA PNG (declared as Greyscale in Octane) for Specularity and Alpha.
And Octane sees :
2 LDR RGB.
4 HDR RGB.
I had a look at your example scene and the counts are correct, but reported for the wrong texture types: Greyscale LDR images are reported as RGBA HDR images. and RGBA HDR images are reported as Greyscale LDR images. It will be fixed in the next release.
In case you were wondering: LotusElan_COLOR.bmp and LotusElan_SPEC.png were both used as RGBA (e.g. in the diffuse channel) and as greyscale image (in bump channel), which is why they are counted twice.
roeland
Dmi3ryd wrote:Hello everyone. Could you please tell me, how can I remove strange artifactct from geometry?
https://www.dropbox.com/s/zqkvfw8dgpwpc ... -41-43.png
Your geometry may be exported as double sided polygons, i.e. for every polygon there are two polygons in the object file with the normals facing the opposite side. Otherwise can you send us the OBJ file so we can have a look?
Roeland
abstrax
Dmi3ryd wrote:Any ideas?
Very likely a scale or FOV issue. Can you post an example?
abstrax
resmas wrote:
abstrax wrote:
Vue2Octane wrote:There seems to be an issue in 2.01 with opacity map and obj import.
In v1.55 and v2.0 obj import and default greyscale image for opacity map is ok, but in 2.01 I have to reload as RGB image. Have all three versions installed and checked with all of them.
This will be fixed with the next release.
Hello there, if I open projects from 2.0 and 1.55 in the new 2.01 all the greyscale images are not loaded. I cant reload them because some of the materials are from LiveDB so I don't know where are the textures.
Where are stored the textures from a material downloaded from LiveDB?
Well I think this is the same problem that was reported. All goes well in the older versions.
Cheers
resmas
Thanks for reporting. We are currently looking into it and it will be fixed with the next release.
manalokos
There is a recurrent bug that has been there since early 1.xx, when I pick a mesh node with many materials and point out to another obj file that has some changes it crashes when loading.
manalokos
There is a functionality that was lost in 2.xx
When applying values I would input a number and use the TAB key to apply a value to the next box. i.e.
Applying 0.1 to x scaling and 0.1 immediately to y scaling.
Now we have to click on the bar with the right mouse.
TAB key should make it able to input values directly onto the next box.
smicha
manalokos wrote:There is a functionality that was lost in 2.xx
We've reported it earlier.
+1
