OctaneVR for NUKE & After Effects (Alpha) free download
win
Great News!
OctaneVR for NUKE, and OctaneVR for After Effects (Alpha) is available now for free download with any active OctaneVR subscription.
To claim your free download, you must have an active OctaneVR subscription.
Login to your Octane user account, go to the Downloads page and select OctaneVR for NUKE, or OctaneVR for After Effects.
Please note that the current version of After Effects v3.07 Test 3 is an Alpa version.
If you have any queries, please contact the Octane Helpdesk team - [email protected]
Visutainment
When trying to apply the OctaneVR effect to a solid I always get either "invalid filter error" or that the octane.aex plugin couldnt be loaded. (126)
Using Win10x64, AE CC2017
Visutainment wrote:When trying to apply the OctaneVR effect to a solid I always get either "invalid filter error" or that the octane.aex plugin couldnt be loaded. (126)
have you extracted files to in AE main folder as in packed structure?
Visutainment
yes exactly as in the packed structure.
This build is not a VR version i think. That should be your problem.
Visutainment
aoktar wrote:This build is not a VR version i think. That should be your problem.
"OctaneVR for #NUKE, and OctaneVR for #AfterEffects (Alpha) is available now for free download with any active #OctaneVR subscription. "
This was posted on FB recently.
glimpse
mm, I've just copy pasted what was written in the first post "OctaneVR for NUKE, and OctaneVR for After Effects (Alpha) is available now for free download with any active OctaneVR subscription."
hellguy
OctaneVR for After Effects 3.07 T4-R1 Alpha
You can download via the customer downloads area here:
https://render.otoy.com/account/downloa ... LL&ver=ALL
Current limitations / Known issues:
  • If you sign in with an account with no available subscriptions, the application will crash. In order to avert this crash, and sign in with a OctaneVR subscribed user, you need to delete the files in `%APPDATA%\OctaneRender\` (DO NOT DELETE any of the sub-folders)
  • Objects accept only .orbx files.
  • Under and Octane Render Effect, only object-1 and object-2 are supported in the Node Graph Edit.
  • The alpha test version is built against SDK 3.07, however, some 3.07 features are not yet implemented in the plugin.
If you encounter any issues using the plugin, please contact us at [email protected]
hellguy
This should be fixed in the latest Alpha release (above).
