Issues running OctaneVR 2.23.1on OSX 10.9.5 and 10.10.2
name
Hi, I've copied over the app from the disk image on 2 separate MBP's and both have the same error when trying to launch the app.
Any ideas on minimum system requirements or why this issue is occurring?
Error:
OctaneVR 2.23.1 cannot be opened because of a problem.
Check with the developer to make sure OctaneVR 2.23.1 works with this version of OS X. You may need to reinstall the application. Be sure to install any available updates for the application and OS X.
Click Report to see more detailed information and send a report to Apple.
Process: octane [1510]
Path: /Applications/OctaneVR 2.23.1.app/Contents/MacOS/octane
Identifier: com.otoy.octanerender
Version: ???
Code Type: X86-64 (Native)
Parent Process: launchd [854]
Responsible: octane [1510]
User ID: 1968582315
Date/Time: 2015-05-01 15:42:59.712 +0100
OS Version: Mac OS X 10.9.5 (13F34)
Report Version: 11
Anonymous UUID: 4A12B287-39DB-FB1B-B141-708054557690
Sleep/Wake UUID: 25DD4D9A-4252-4C76-8F46-96AC800657C5
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: /usr/local/cuda/lib/libcuda.dylib
Referenced from: /Applications/OctaneVR 2.23.1.app/Contents/MacOS/octane
Reason: image not found
Binary Images:
0x7fff6e6f1000 - 0x7fff6e724817 dyld (239.4) <7AD43B9B-5CEA-3C7E-9836-A06909F9CA56> /usr/lib/dyld
Model: MacBookPro8,2, BootROM MBP81.0047.B27, 4 processors, Intel Core i7, 2 GHz, 8 GB, SMC 1.69f4
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 512 MB
Graphics: AMD Radeon HD 6490M, AMD Radeon HD 6490M, PCIe, 256 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x0198, 0x393930353432382D3035312E4130304C4620
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x0198, 0x393930353432382D3035312E4130304C4620
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.98.100.22)
Bluetooth: Version 4.2.7f3 14616, 3 services, 23 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: Wi-Fi, AirPort, en1
PCI Card: pci11c1,5901, IEEE 1394 Open HCI, Thunderbolt@191,0,0
PCI Card: Apple 57761-B0, Ethernet Controller, Thunderbolt@192,0,0
PCI Card: pci12d8,400e, USB Open Host Controller, Thunderbolt@197,0,0
PCI Card: pci12d8,400e, USB Open Host Controller, Thunderbolt@197,0,1
PCI Card: pci12d8,400f, USB Enhanced Host Controller, Thunderbolt@197,0,2
Serial ATA Device: OCZ-VERTEX4, 256.06 GB
Serial ATA Device: HL-DT-ST DVDRW GS31N
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: USB Receiver
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM2070 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Hub
USB Device: IR Receiver
USB Device: Hub
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: Display Audio
USB Device: FaceTime HD Camera (Display)
USB Device: Apple Thunderbolt Display
Thunderbolt Bus: MacBook Pro, Apple Inc., 22.1
Thunderbolt Device: Thunderbolt Display, Apple Inc., 1, 22.2
J.C
Octane works only with Nvidia GPUs which support CUDA technology. Looking at your log I see you have an ATI GPU which will be supported with Octane v3.
System – Windows 11
name
Thanks, I found min HW specs and saw that. Another reason to build that new PC.
Matt
