Version 3.03.3-R1 (11.08.2016)
zoppo
Version 3.03.2-R1 - "Minimize net traffic" gets always re-enabled as soon as you close and again open the settings window. The only way to prevent this is to keep the settings minimized.
C4D 2025 | Win10
L_Sprangers
Experimental Pascal support yet? Or is that just with Standalone?
zoppo
L_Sprangers wrote:Experimental Pascal support yet? Or is that just with Standalone?
According to a guy in another forum his 1080 works.
C4D 2025 | Win10
schodt wrote:Thanks for the great work AOktar. I don't know if anybody has reported this before, but here goes: When using the "Stage" for multiple cameras with motion blur enabled, the motion blur goes nuts when the camera changes from one camera to another. It is usually 2 frames between the camera change that are with messed up motion blur.
thanks. I know this issue. I may check it for a solution.
zoppo wrote:Version 3.03.2-R1 - "Minimize net traffic" gets always re-enabled as soon as you close and again open the settings window. The only way to prevent this is to keep the settings minimized.
it should be fixed for latest build. thx for reporting.
yes it's same core. so should work.
zeigg
Can confirm that this build is working with my 1080.
Win10 | i7 5960X | Nvidia GTX 1080 FE & EVGA GTX 1080 Ti Sc | 64 GB RAM
Octane Standalone | Octane C4D Plugin
Raoul
Any indication of how its performing.. I assume it hasn't been optimised for yet.. but has anyone run a benchmark on it?
Fascinated to know if we are going to see any improvements over the 980tis etc.
Ta!
zeigg
Ta!
No, it is not optimized. I'm not sure how it stacks up next to a 980 Ti as I don't believe that OctaneBench supports Pascal yet.
The current build Octane is running on is a hybrid between CUDA 7.5 and 8.0 RC. I believe the team is waiting on the full CUDA 8.0 release to optimize everything.
I upgraded from a 780 Ti to the 1080 and the speed difference for me is quite nice.
According to this post, the unoptimized build with 1080 is close to 980 Ti:
viewtopic.php?p=283092#p283092
luoluokk
when I open Cinema 4D with v3.03 ,it appears a window "could not get a license because your sso session has expired , and let me re-enter password" , i input the password for several times but i can't log in yet.
but when v3.02 , i login successfully but due to my graphics card gtx1080 , v3.02 can't run.
