bug v3.03.2 - 4.12 [TEST]
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Elvissuperstar007
error
PMC
Started logging on 29.07.16 13:56:33
OctaneRender 3.03.2 (3030002)
CUDA error 2 on device 0: The API was unable to allocate enough memory to perform the requested operation.
CUDA error 2 on device 1: The API was unable to allocate enough memory to perform the requested operation.
-> failed to allocated device memory
device 0: failed to upload data texture 4 of context 0
device 1: failed to upload data texture 4 of context 0
device 1: failed to upload data texture 30 of context 0
-> failed to allocate device array
device 1: failed to upload data texture 31 of context 0
CUDA error 700 on device 1: Kernel tried to load or store to an invalid memory address. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
-> kernel execution failed (report)
-> failed to launch kernel (ptBrdf2)
device 1: PMC kernel failed
CUDA error 700 on device 0: Kernel tried to load or store to an invalid memory address. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
device 0: PMC kernel failed
-> failed to load symbol data to the device (deep_data)
device 0: failed to upload the deep params
device 1: failed to upload the deep params
could not request a tonemap because we don't have any renderthreads available.
octane 3.03.2 160729 184827.log
(3.52 KiB) Downloaded 295 times
Elvissuperstar007
это происходит с регион рендером, после я даже сохранить не могу рендер..блин рендерю раз 10 уже, памяти хватает судя по скрину
octane 3.03.2 160729 223320.log
(1.72 KiB) Downloaded 303 times
Yan
I get the exact same error with Cinema 4D plugin.
Is there a fix for this? It only happens since V3.
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, 4x EVGA GTX 1080Ti, Octane-for-C4D 4.x.x, Nvidia 398.82
coilbook
Yan wrote:I get the exact same error with Cinema 4D plugin.
same here with 3ds max
Isolate objects+materials until error disappear and find what's causing that. Then you can report the scene if it's spesific to somethings.
Return to “Bug Reports”
