I have problem with NVLink:
I applied the bridge to my two Titan RTX cards (24GB each). Then I activated SLI. I have Nvidia Studio Drivers 441.61. Win 10 tells me about a total of 90GB GPU memory. This is strange because it should be 48GB.
Well in Octane I put up a scene renders it but get a "CUDA error 2 on device 1: out of memory -> failed to allocate device memory" like without NVLink. The scene was about to render with less vegetation. So the error is about memory.
In the other threads here I read about an extra memory bar which is about to appear when the memory gets shared to the other GPU. But Octane just behaves like without NVLink.
It also doesn't matter if I tick out of core memory.
Whats wrong here?
OctaneRender® for 3ds max® v2020.1-RC2 - 10.06 TEST
PURE3D Visualisierungen
- paride4331
Hi samsue,samsue wrote:have a slave for this version?
when the stable version will be released.
- paride4331
Hi mbetke,mbetke wrote:I have problem with NVLink:
Whats wrong here?
could you try installing this Nvidia driver?
https://www.nvidia.com/download/driverR ... 7537/en-us
Set out of core around 64GB and don't forget Nvlink works with textures only.
- paride4331
Hi Elvissuperstar007,Elvissuperstar007 wrote:Started logging on 02.04.20 04:37:13
OctaneRender Enterprise 2020.1 RC2 (8000004)
CUDA error 2 on device 0: out of memory
device 0: failed to allocate post-fx buffer
denoiserThread0 : Not enough free memory to run the denoiser. Required memory 453.47 MB
denoiserThread0: CUDA_ERROR_OUT_OF_MEMORY: out of memory
. Restart required
viewtopic.php?f=80&t=74143&p=380170#p380170
paride4331 wrote:Hi mbetke,mbetke wrote:I have problem with NVLink:
Whats wrong here?
for the Titan RTX cards the octane combines the vram? For 2080Ti too?
Hi mbetke,
Paride, it just doesn't work in production for me. I updated drivers and set to out of core to 64GB. My scene is nothing special. Around 44Mio tris in whole scene with lots of small geometries objects and textures. Some trees and such stuff. Just arch-viz. No large 150Mio tris mesh or other fancy stuff.
Denoiser also kills the rendering with memory allocation error.
How can I analyze further? This is really annoying to have a top-notch GPU rig here and the announced feature just don't work and I also have no possibility to check what's wrong.
EDIT: Sometimes it stopped on same scene with 0.1GB with denoiser. Without denoiser it works and extends 2.5GB. Really strange that same scene sometimes works and sometimes not. All static. No simulations/animations in there.
Also gets killed when just changing exposure dirung render.
denoiserThread0 : Not enough free memory to run the denoiser. Required memory 604.92 MB
denoiserThread0 : Initialization failed. Restart required
OptiX error for device 1: [ERROR] "sbt->raygenRecord" is null
OptiX API error for device 1: Invalid value
device 1: path tracing kernel failed
ParidePURE3D Visualisierungen
I use this configuration. One denoises. The other ones tones. Both render.
