Upgrade to Octane 3
Forums: Upgrade to Octane 3
Carrara (Integrated Plugin developed by Sighman)
Upgrade to Octane 3
Postby tschwenke » Mon May 23, 2016 11:33 am
tschwenke Mon May 23, 2016 11:33 am
I just received an email that Octane 3 is available. However, when I want to upgrade, I can only upgrade Standalone and Poser versions, not Carrara version. Will there be an upgrade for Carrara anytime soon?
Best wishes,
Thomas
http://www.thomas-schwenke.me
Houdini 18.5 || Win10 || i7 + 1 x RTX3080
tschwenke
Re: Upgrade to Octane 3
Postby 3dage » Mon May 23, 2016 4:00 pm
3dage Mon May 23, 2016 4:00 pm
I have the same issue here,. ...no upgrade option for the Carrara plugin,
AMD Athlon II X4 640 Quad core 3ghz.
12GB ram , 2TB HDD Win 7 pro 64bit
Nvidia Geforce GTX 650 Ti 2GB
3dage
Postby dimdedi » Mon May 23, 2016 8:47 pm
dimdedi Mon May 23, 2016 8:47 pm
Same here !
dimdedi
Postby Sighman » Tue May 24, 2016 6:45 am
Sighman Tue May 24, 2016 6:45 am
Now that there is a V3 version of OctaneRender for Carrara in the store, can you please check again to see if you can bundle the upgrade.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Sighman
Postby tschwenke » Tue May 24, 2016 7:02 am
tschwenke Tue May 24, 2016 7:02 am
Hi Sighman,
Yes, works great. Thanks!
Will it be possible to work with 2.x after upgrading to 3.x?
Best wishes,
Thomas
tschwenke
Postby Sighman » Tue May 24, 2016 7:40 am
Sighman Tue May 24, 2016 7:40 am
As far as I know it will. There has been some chatter that 2.25 was throwing a fit after a license upgrade but that has either been or will be resolved.
Sighman
Postby protovu » Tue May 24, 2016 12:59 pm
protovu Tue May 24, 2016 12:59 pm
I am wondering if there is any consideration for the length of time one has held a license. Less than 5 months seems a bit quick for a cost bump, particularly since this latest version 3, has been the most operable version given my work flow.
protovu
Postby Sighman » Tue May 24, 2016 3:29 pm
Sighman Tue May 24, 2016 3:29 pm
protovu wrote:I am wondering if there is any consideration for the length of time one has held a license. Less than 5 months seems a bit quick for a cost bump, particularly since this latest version 3, has been the most operable version given my work flow.
If you want to stick with version 2 I will back port render room rendering to version 2. Will that satisfy your workflow needs?
Sighman
Postby tschwenke » Tue May 24, 2016 7:40 pm
tschwenke Tue May 24, 2016 7:40 pm
Sorry to disturb again :)
I installed Octane 3. However, there are some problems.
a) On the donwload portal, it says I download version 3.0.20.11. But when I open the window, it says 3.00.0011.
b) Volumetric clouds does not seem to work. Do I something wrong here?
Best wishes,
Thomas
tschwenke
Postby protovu » Tue May 24, 2016 8:07 pm
protovu Tue May 24, 2016 8:07 pm
Thank you, Simon. That might be a way to go, but I do like being in the loop as things develop.
questions though:
Will my current 3.0 version stop working at some point if I do not formally upgrade? A license only applies to a single version, but how long is a version good for? 6 months?
I should probably contact Otoy with these questions.
protovu
Next
Return to Carrara
Who is online
Users browsing this forum: No registered users and 3 guests
Wed Jun 05, 2024 9:31 pm [ UTC ]
