HELP!!lua script and "open editor" problem。
Forums: HELP!!lua script and "open editor" problem。
Forum for OctaneRender Lua scripting examples, discussion and support.
Postby butterhuang » Fri Jul 03, 2015 2:28 pm
butterhuang Fri Jul 03, 2015 2:28 pm
When I excute script in editor, the output will be blocking。
During excuting, I can't see only output log which I use octane.common.print or print function to print in the script。
If the script exit, the all output log can display in the Output pannel together。
My script will excute with a long time。 Even I output the log to a log file,the output content still be blocked unitl the script exit。
How can I avoid this?
butterhuang
Re: HELP!!lua script and "open editor" problem。
Postby stratified » Tue Jul 07, 2015 9:04 pm
stratified Tue Jul 07, 2015 9:04 pm
Yes, when a script is executing, the user interface is disable. This is by design, we don't want users fiddling around with the nodes while a script is executing because this can lead to unexpected behaviour.
You cannot avoid this. Some users work around this by displaying a progress bar.
cheers,
Thomas
stratified
Postby butterhuang » Wed Jul 08, 2015 9:00 am
butterhuang Wed Jul 08, 2015 9:00 am
stratified wrote:Yes, when a script is executing, the user interface is disable. This is by design, we don't want users fiddling around with the nodes while a script is executing because this can lead to unexpected behaviour.
cheers,
Thomas
yeah, you can just block the editor toolbar and input area, but now the output area is blocked. it is not writable!
butterhuang
Postby haze » Thu Aug 20, 2015 10:46 pm
haze Thu Aug 20, 2015 10:46 pm
butterhuang wrote:When I excute script in editor, the output will be blocking。
You might want to consider using octane.gui.dispatchGuiEvents(1) to flush output to the output window of the script editor. Something like the following:
local ffi = require("ffi")
if ffi.os ~= "Windows" then
    print("This script is only for windows")
    return
end
ffi.cdef [[
void Sleep(int ms);
int poll(struct pollfd *fds, unsigned long nfds, int timeout);
function sleep(t)
    ffi.C.Sleep(t*1000)
end
co = coroutine.create(function()
    for i=0,100 do
        if i == 50 then
            coroutine.yield()
        end
        print(i)
        io.flush()
    end
end)
coroutine.resume(co)
octane.gui.dispatchGuiEvents(3)
sleep(5)
haze
Postby butterhuang » Tue Aug 25, 2015 5:23 am
butterhuang Tue Aug 25, 2015 5:23 am
such an ugly solution.
    return
end
ffi.cdef [[
void Sleep(int ms);
function sleep(t)
    ffi.C.Sleep(t*1000)
end
    for i=0,100 do
        if i == 50 then
            coroutine.yield()
        end
        print(i)
        io.flush()
    end
end)
sleep(5)
butterhuang
Postby haze » Tue Sep 01, 2015 1:21 am
haze Tue Sep 01, 2015 1:21 am
Use this line only:
haze
Return to Lua Scripting
Who is online
Wed Sep 30, 2020 11:00 pm [ UTC ]
