Hello,
When I changed userdata to "GUID=something" and rebooted instance, the service does not start. Through RDP I can see in task manager that tcpsvcs.exe is not running. Why is that? Can I start it manually? Or what can I do?
Best regards,
FlashT
tcpsvcs.exe won't run...
Can you check and see if the "WebCL" service is started? If it's not, feel free to start it. Once it's started, you should see the tcpsvcs.exe processes show up in Task Manager.
- ShanonLoughton
- Contact:
I see the same thing, especially when instance is Stopped for decent amount of time (> 1 day)
in Windows Task Manager
WebCL Service
WebCL ConfigSvc
Both running. You can stop and restart them but tcpsvcs.exe does not appear at all in the list, as running nor stopped. Tried Rebooting instance, tried stopping, then forcefully stopping, then starting again. Same thing.
AWS deets:
Instance ID
i-XXXXXXXX
Public DNS
ec2-x-y-z-w.compute-1.amazonaws.com
Instance state
running
Instance type
g2.2xlarge
Availability zone
us-east-1a
Private IPs
x.y.z.w
Security groups
Octane Cloud Workstation-1-AutogenByAWSMP-1. view rules
AMI ID
AMI-OTOY-OCTANE-WINDOWS_1.0-1765694b-3372-4e71-9d75-0703468ad20d-ami-8f5d16e6.1 (ami-295e0b40)
Platform
windows
Launch time
March 12, 2014 8:18:13 PM UTC+8 (less than one hour) <----I cant tell exactly when I first made the Instance, It was Late Feb 2014.
WebCL Service
WebCL ConfigSvc
AWS deets:
Instance ID
i-XXXXXXXX
Public DNS
Instance state
running
Instance type
g2.2xlarge
Availability zone
us-east-1a
Private IPs
x.y.z.w
Security groups
AMI ID
Platform
windows
Launch time
- vamsigudipati
I have same problem, the tcpsvcs.exe process doesn't show up in the task manager. And so I am not able to connect to the instance through URL. Could you please let me know how to start this process manually?
Warm regards,
Vamsi
Warm regards,
Vamsi
- vamsigudipati
Basically the above problem is seen after migrating the AMI from a public subnet to a private subnet.
Vamsi
Vamsi
Did you include an internet gateway in the private subnet? WebCL currently requires an active internet connection in order to start.
- ShanonLoughton
- Contact:
g2.2xlarge now available in Sydney, Australia! Yay
But ergghhh same issues as above! Worked the first time, then Stop instance, and Start instance again and no tcpsvcs.exe running. WebCL.exe is running.
Anything else I can try?
