Dust Test
Forums: Dust Test
Re: Dust Test
Postby mikeadamwood » Fri May 12, 2017 1:19 pm
mikeadamwood Fri May 12, 2017 1:19 pm
Sorry to dig up an old thread but does anyone know when exporting from 3D Coat which normal map node to work with.. There's normal map software presets and not sure which one to select?
Windows 10 | ASUS Pro WS X99 SAGE II | Intel Core i9-10900X | 64GB Corsair Vengence | 3x Evga GTX 1080ti
mikeadamwood
Re: Dust Test
Postby PyatFre » Wed Jul 26, 2017 10:51 am
PyatFre Wed Jul 26, 2017 10:51 am
Dust looks quite good, but still something's missing, like it's a very "plastic studio dust" maybe try to play with the lighting..
PyatFre
Re: Dust Test
Postby grimm » Wed Oct 25, 2017 6:51 am
grimm Wed Oct 25, 2017 6:51 am
Thanks PyatFre! Wow, sorry this took so long to respond. You're right it's doesn't look quite right, it was more of a work in progress. I was thinking of adding a particle system on top of the texture to get more of a 3D effect, hopefully more realistic as well. Here is a test image I was playing around with, it would be better with more random shaped dust particles, I just used a iso sphere instance. This particular test uses 120000 particles.
grimm
Re: Dust Test
Postby grimm » Wed Oct 25, 2017 6:54 am
grimm Wed Oct 25, 2017 6:54 am
mikeadamwood wrote:Sorry to dig up an old thread but does anyone know when exporting from 3D Coat which normal map node to work with.. There's normal map software presets and not sure which one to select?
Sorry mikeadamwood, this just passed me by for some reason. I just export a tangent normal map from 3D-Coat and import it into Octane. Or if the texture is very deep I export a displacement map and use that.
Jason
grimm
Re: Dust Test
Postby Zernam » Tue Aug 21, 2018 12:58 pm
Zernam Tue Aug 21, 2018 12:58 pm
grimm wrote:Thanks PyatFre! Wow, sorry this took so long to respond. You're right it's doesn't look quite right, it was more of a work in progress. I was thinking of adding a particle system on top of the texture to get more of a 3D effect, hopefully more realistic as well. Here is a test image I was playing around with, it would be better with more random shaped dust particles, I just used a iso sphere instance. This particular test uses 120000 particles.
I don't know which lighting PyatFre is talking about. The key to good dust is irregular shape, and good normal and roughness maps. I've never tried 3D coat but I think it's similar to other texturing software.
Zernam
Previous
Return to Works In Progress
Tue Jun 04, 2024 2:29 pm [ UTC ]
