Ok let's begin with serious things ...
radiance
it could be a sampling distance issue.
I'll check it out tomorrow, time to sleep now ;)
Radiance
nuverian
So will there be direct lighting in beta 2? I though it will be there somehow
http://www.nuverian.net
nuverian.deviantart.com
i7 920 2.66, 6G RAM, GTX 660 Ti, Win7 64x.
pixym
nuverian wrote:So will there be direct lighting in beta 2? I though it will be there somehow
Have a look at this thread: http://www.refractivesoftware.com/forum ... 8455#p8455
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10 64
NET RENDER : MB ASUS P9X79 - Intel i7 - Ram 16GB - Two RTX 3080 TI - Win 10 64
enricocerica
radiance wrote:
enricocerica wrote:Thanks guys for comments,
n1k:I used the opacity slided to get some transparency
javadevil:yes I noticed that issue, I activated the smooth but it does not solved the problem.
is your bump map resolution large enough ?
what's the image size ?
Radiance
It's a 400x400 map but it should be tiled about 4x
http://www.myline.be
buda
cuda
Sam
Sam`s image got the same problem: viewtopic.php?f=5&t=863
Are textures filtered in some way in Octane?
Nice image between, looks very realistic
Like I said in the other topic, its because Im very close to the map, and its low-res
But its true that the pixels are square, and not very filtered
Holy moly ! :shock:
pedrojafet
Amazing job... A real shot. 8-)
Cheers ;)
Win 7 PRO64 | Geforce GTX2750 - 1.8GB | MB ASUS w/ i5 2500 | 8GB
bluescorpion
Do I see noise on the water?
MacPro 2.8Ghz Dual Quad-Core Intel Xeon; 18GB Ram, Nvidia GeForce 8800GT; Mac OSX 10.6.4
