man enrico you are like the master of blender.
a few questions:
ever worked on feature film production? if not then im amazed
how long have you been using blender
how long have you been doing 3D in general
what do you do during exporting obj, importing obj, loading obj
Concrete villa
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
If I understood well, you make only a render of the displacement with Blender and a render of the scene with Octane Render. Then you use Photohoshop or Gimp for the final editing?Octane does not provide any displacement function for now, so when I want displacement I do it in Blender and I export the result with displacement, it increases the mesh size but I manage it based on the view, low disp for far objects and higher for near one
- enricocerica
- Contact:
No, no, everything is rendered in Octane but I first apply the displace modifier so the mesh is displaced at exporting time.dadou351 wrote:If I understood well, you make only a render of the displacement with Blender and a render of the scene with Octane Render. Then you use Photohoshop or Gimp for the final editing?Octane does not provide any displacement function for now, so when I want displacement I do it in Blender and I export the result with displacement, it increases the mesh size but I manage it based on the view, low disp for far objects and higher for near one
http://www.myline.be
- EasternMerchant
ok thanks
Athlon 62 X2 2.6GHZ
Corsair XMS2 2GB DDR2 800
Geforce 8500GT 512MB
Windows XP Sp3 32bit
OK I finally understood
I use Cinema 4D and the displace modifier function is called displace deformer with MOGRAPH.
It is not evident but I approach the purpose ^^
I find that Blender allows to make some good work but I really have difficulty in using him in spite of the version 2.5!
Thank you again
Thank you again
