Concrete near the lake
enricocerica
Not much time to work on my last project so I decided to revisit an old project to heat up my video cards ;)
http://www.myline.be
PAQUITO
Lots of potential on that scene, but I think is not well solved. It looks like an abandoned place with all that rust textures and the high contrast. I assume it is retouched. Can we see the raw render?
AMD FX8350 8 cores. 16GBs RAM
GTX690
Win8 64.
paoloverona
I like the mood that you give to your renders Enrico, this one sounds too much "melancholy" for my tastes but I like that your renders gives some emotional impact.
I'm agree with Paquito.....would be amazing compare the raw with the retouched
intel i7 3820 3.6GHz, 16Gb 1600Hz, windows 7 professional 64bit, gtx 580 3Gb x2, Octane 3dsMax 2.58
Refracty
I don't think there is much of retouch work done in this image.
I like the mood and environment.
I think it would be nice to step a few meters back and see a bit of the lake / water.
enricocerica
Hi and thanks for viewing,
I added the original image to show the result before postprocessing.
I wanted some dramatic result which imo works fine with this environment, I already changed a bit the result to get less contrast but will publish later on to let you first comparte the two images.
I also added more images ;)
Refracty
well done enrico
paoloverona
super the new images
PAQUITO
The last three images are stunning. Congratulations.
About the general shot, if you don´t mind, I´ve been playing a bit with post production and got this result. You can achieve greater results using a material_ID pass.
GTX690
Win8 64.
PAQUITO
By the way... How do you combine an hdri environment with a daylight?
GTX690
Win8 64.
Carl S.
PAQUITO wrote:The last three images are stunning. Congratulations.
This result looks washed out and low contrast IMO.
