Hi there,
I have a few objects in my scene, with animated visibility. I've checked in the "refresh geometry on every frame" option, to no avail. the objects that are invisible stays invisible on the frames on which they become visible in poser. any ideas what might be wrong?
refresh geometry every frame doesn't work ?
It depends on how you animate invisiblity
Refresh geometry only reloads the objects which are present, and when they are initially invisible, they are not present and therefore not updated.
I think in this case the option in Setup: Keep Materials from Invisible Items will work.
If you animate visibility in materials you should also check reconvert materials each Frame (make sure you save the octane materials as Poser materials)
you can of course also use Refresh Scene each Frame.
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
