blur only the edge of object
Andygraph3D
is it possible blur only the edge of object and no all shot ?
TRRazor
You would need some sort of shape blur for this - not sure if OctaneRender has anything similar.
I would probably do this by doing it in post.
Do you wish to blur the textures, geometry or both?
Andygraph3D
only geometry
I think you would need to do this in Gimp or Photoshop.
Andygraph3D
gimp or photoshop make it on all frame .. i need make it only on geometry and without post processing.
You could increase the Aperture to something like 50 or 100, then set the focus point on the geometry that is not to be blurred.
Andygraph3D
I need to slightly blur the contours of all geometries regardless of focus (in that case it would add to blur).
This is to give more realism you object boundaries otherwise (without having to blur even textures ..
TRRazor
I'm pretty sure, that this is not possible without calculating vectors manually and then enter them into some sort of object-blur as it comes in Photoshop, where you can blur from the shape of an object.
Octane - as far as I know, doesn'T support such a thing.
Andygraph3D
Programmatically if you can apply an anti-aliasing you could add a function to blur ..
anyway will be a cool feature ;-)
Return to “Poser”
