Image MAps w/Blender node
Forums: Image MAps w/Blender node
Postby bpzen » Wed Aug 07, 2013 3:46 pm
bpzen Wed Aug 07, 2013 3:46 pm
Hi all
I am running into a challenge with two images maps feeding into a blender node then feeding into the Diffuse setting in poser. When Octane imports its only taking one of the image maps.
Is there a set up were I can use both image maps to blend and get the desired result as I do in Poser?
thanks
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
bpzen
Re: Image MAps w/Blender node
Postby wimvdb » Wed Aug 07, 2013 6:12 pm
wimvdb Wed Aug 07, 2013 6:12 pm
You can use the material mix node or mix node (depending on your needs).
In the value component, add the blending image or value
Then add each of the two images in a texture node.
You may need to invert the blending image if the images are reversed
Configuration: Windows 10 64bit Creators Edition, I7 6850K, 128GB, 2 GeForce 1080ti, P11 Pro SR6
wimvdb
Return to Poser
Who is online
Users browsing this forum: No registered users and 2 guests
Wed May 27, 2020 3:05 am [ UTC ]
