A Poser Flame
RGUS
Has anyone been able to get a decent looking candle flame with light emission and flame texture working yet... so many nodes, so many nodes...
RAM: 64GB
OCTANE PLUGIN VERSION: 2025.6.0.4.09 Prime BETA
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
IMO the flame geometry would be a poor emitter - so use a flame geometry and setup a non-emitter material (think there is a flame material in the livedb). Then add a small sphere or cube around the flame, set it up as an emitter, and set it's opacity to 0.
RGUS
Sounds like it actually might work.... see lateral thinking... and knowing the software. Thanks Paul
RAM: 64GB
samhal
This is something I did earlier base on what Paul and wim posted. Is this close to what you're looking for Deane?
i7 6800K (6 core), 24 GB, GTX 1080 8gb, Titan X 12gb
RGUS
Yup exactly... now send me the nodes...
RAM: 64GB
samhal
RGUS wrote:Yup exactly... now send me the nodes...
:D
Here's what my "flame" looks like:
...and the invisible "ball" that's the real light source:
Flame:
Ball:
RGUS
Thanks for that... couldn't see the wood for the trees for a while there.
RAM: 64GB
Pandarr
RGUS wrote:Thanks for that... couldn't see the wood for the trees for a while there.
Just be sure to set neither on virtual fire.
TRRazor
Am I seeing that correctly?
The flame AND the ball are both light emitters?, isn't that a bit of overkill? Although the result is pretty lifelike.
I achieved a pretty decent fire effect while setting a 2D-sprite (essentially just a one sided pane with a transparency map and a texture on top of it) to Diffuse and added a orange-reddish RGB color emission to it.
You can see the result here:
https://s3.amazonaws.com/bw-1651cf0d2f7 ... 495590.jpg
Might be a bit less render intensive due to there being only light source. Hope this helps! :)
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
samhal
TRRazor wrote:Am I seeing that correctly?
Very nice render! But...IMO the fire looks unrealistic. It's too bright and that's the problem with using only the 'flame-fire' as the only emitter. What I do is set the intensity of the flame to look right and control how 'bright' I want the light to cast with the ball emitter. Again, thats just my opinion.
Return to “Poser”
