OcDS FIRST RENDERS - FIRST PRIDE :) post here...
Forums: OcDS FIRST RENDERS - FIRST PRIDE :) post here...
DAZ Studio (Export Script Plugin developed by Tugpsx; Integrated Plugin maintained by Paul Kinnane)
Re: OcDS FIRST RENDERS - FIRST PRIDE :) post here...
Postby face_off » Mon Dec 02, 2019 12:03 am
face_off Mon Dec 02, 2019 12:03 am
Does the skin look to much like wax?
May I suggest holding off until the 2020.1 test release (available in the next week), which should have the Random Walk SSS medium, which should provide much better SSS for human skin.
Postby Kanne » Mon Dec 02, 2019 11:16 am
Kanne Mon Dec 02, 2019 11:16 am
Thanks for your replay. Glad to hear it will be that soon, looking forward to test it.
Kanne
Postby Kanne » Mon Mar 16, 2020 6:44 pm
Kanne Mon Mar 16, 2020 6:44 pm
Despite having troubles with seams and performance problems when woking with large node setups in the Daz GUI the results are getting better. At least i hope so :)
Kanne
Postby Banti » Tue Mar 24, 2020 2:05 pm
Banti Tue Mar 24, 2020 2:05 pm
Kanne wrote:Despite having troubles with seams and performance problems when woking with large node setups in the Daz GUI the results are getting better. At least i hope so :)
Lovely Render :)
Do you mind sharing you shader setup? I love looking at other peoples work and learn something new :)
Banti
Postby Kanne » Thu Mar 26, 2020 8:39 am
Kanne Thu Mar 26, 2020 8:39 am
Lovely Render :)
Thank you. I bought this shader from the blender market https://blendermarket.com/products/skin ... ane-render adpated it to Daz3D and made a few changes / adjustments / rearrangements. I got rid of the cavity-map handling in the shader for two reasons. First Daz3D models usally don't come with cavity-maps. You can create curviture maps from normal maps with tools like Knald, but tbh i dont havn't any experiance with this kind of maps and i'am not sure if they are the same or not. Maybe in the future i will take my time to look into that topic and give it a try. Second, the node setup is quite large and it seems the node graph editor in Daz3D has problems to handle that much. The UI gets really slow and sometimes even crashs. Maybe i have bad settings, but havn't found anything to fix it currently.
Another downside of the shader is the use of high density values in the scattering nodes which cause faceting (mentioned in this thread: viewtopic.php?f=44&t=73989). I recently opened an issue at otoy for that. I hope they can provide some help with that problem.
For the node-setup, since this shader is bought i guess i'am not allowed the share the detailed node setup because of legal reasons. Sorry. But i think i could give a brief overview if you would like.
Kind regards.
Kanne
Postby Banti » Thu Mar 26, 2020 12:24 pm
Banti Thu Mar 26, 2020 12:24 pm
Kanne wrote:
The attachment Susann48_3.png is no longer available
Lovely Render :)
Kind regards.
Funnily enough i bought this exact shader 2 month ago ^^
But i never really got it to work like i wanted because of the reasons you already mentioned. The GUI gets very laggy and there are maps that i just never use.
I usually use my own shader that is a very basic specular/high density one. But as you said the current faceting/seam problems make the current plugin version obsolete
for me. I hope they fix this quickly because the RTX acceleration in the 2020 version is something i dont want to miss :)
But if you can give a brief overview of how you got this shader to work i would very much appreciate it :)
This is my skin shader. I only started working with Octane and DAZ for that matter 3 month ago so its really very basic.
My very basic skin shader
Random Walk Skin
Banti
Postby Kanne » Wed Apr 01, 2020 5:29 pm
Kanne Wed Apr 01, 2020 5:29 pm
I opened the orbx file from the marketplace in the standalone and rearranged the nodes to make a sense of it all. Following the setup i rebuild it in Daz by hand to try and learn a thing or two. After finishing it and having i few tests with it i got rid of the cavity parts to reduce the node count. It's still a bit laggy but more handable. I painted my own transmission map / mix map. I tried the transmission map from the redspec shader but they dont work pretty well together. Dispite that, and the other issues mentioned, i didnt had really problems to get it working.
I've been messing around with random walk as well. Had quite acceptable results, but not as good as this shader. I will look into random walk again.
Kanne
Postby UHF » Fri Apr 17, 2020 11:51 pm
UHF Fri Apr 17, 2020 11:51 pm
Not my first render... just sharing. Its meant to be Asuka Langley from Evangelion.
Asuka Langley Is Angry
UHF
Postby Banti » Wed Jun 03, 2020 12:23 pm
Banti Wed Jun 03, 2020 12:23 pm
Just some random medieval clothing i thought looked quite nice.
Banti
Previous
Return to DAZ Studio
Fri Jul 03, 2020 9:09 pm [ UTC ]
