Animating Instances
How are you rendering the scene, in update or full scene reload mode? This sounds like a scene full reload that is changing the instances IDs, or something like that.
If you want to share a scene with this problem, I could take a look at it here.
I've been checking your scene and I'm afraid that there isn't an easy solution to use the random texture with your instances. The problem is that the number of instances is not the same in all the frames, so after reloading the instancer for each frame, the IDs used to get the random texture change. Perhaps you could use a texture in world space to add the random appearance or something like that, but not the random texture node.
