environment ocean
Forums: environment ocean
environment ocean
Postby spigolo » Sun Apr 28, 2019 4:05 pm
spigolo Sun Apr 28, 2019 4:05 pm
Hello,
im building an ocean environment for an yacht animation.
I have the following problems with Octane:
I need to create an horizon as my see is squared (instances of H.O.T. displaced meshes) so I tried to place an hemyspeher with the same HDr image used as an environment to simulate the sky and "cut the sea" at the horizon
BUT:
even if i set the hemisphere to don't cast shadow the environment light doesn't pass through..I know there is not an exclude from radiosity option like in lightwave.
i tried to light the ocean with the hemyspehere and make the hdr mapped on it to emitt light (in place of the environment hdr) but I get too noise and render time increases too much.
So in the end at he moment I uses my environment setup and then I cut the sphere used to create the horizon so its like a cilinder surrounding the scene and the sky light can light everything as the spehere is now an open cilinder (less or more) , but to get the sky hdr on the sphere luminous enough to be coerent with the scene I still have to make it luminous and render times grows again..
Is there a way to have a surface luminous but not emitting light (like in lightwave standard material)? Or someone could suggest a different technique?
I hope is clear what I mean
3dsign studio
Advanced visual communication
http://www.3dsign.it
spigolo
Re: environment ocean
Postby spigolo » Mon Apr 29, 2019 6:04 am
spigolo Mon Apr 29, 2019 6:04 am
Just another question:
Is there a way to use Octane day environment sky and hide the HDR image, so the image is used only for reflections and radiance but
I see only the sky made by Octane?
Everytime I try the various options (backplate visible etc. ) nothing happens
3dsign studio
spigolo
Postby CANDITO » Tue Apr 30, 2019 9:06 am
CANDITO Tue Apr 30, 2019 9:06 am
Hello,
in your sphere emition material settings you have options
to make it just luminous but not affecting diffuse or specular
Cheers
Olivier
CANDITO
Postby spigolo » Mon May 13, 2019 10:19 am
spigolo Mon May 13, 2019 10:19 am
Hello
I found it many thanks!
3dsign studio
spigolo
Return to Lightwave 3D
Who is online
Users browsing this forum: No registered users and 30 guests
Fri Apr 26, 2024 6:40 am [ UTC ]
