I am having a problem with a scene. It's a very large scene with with 53 rather huge objects (2,968,342 polygons in total). 1811 surfaces and 226 images.
It loads and renders mostly fine except for one issue. Some of the textures do not show up on some surfaces. I get a grey surface that I really can't change. Bump and normal maps will be applied to the surface fine but the diffuse channel is grey. Luminosity will also be solid with no texture applied.
If I load just one object into it's own separate scene then the textures render just fine. But it's when everything's together this happens.
the IPR window is saying I'm using about 1/3 the available memory on my video card setup (4gb 680GTX and a 4gb 770gtx) both are actually the exact same card and it's one of those sku renumbering scams that nvidia pulls now and then.
All the surfaces/polygons have only one UV map applied.
It's only the diffuse channel on the glossy surface node.
Both diffuse and emission on the diffuse node.
surfacing problem
Perhaps you have any kind of problem with LW clones rendered as instances ... can you try to disable the "Instance LW Clones" options in the render target root node options panel?Rob49152 wrote:I am having a problem with a scene. It's a very large scene with with 53 rather huge objects (2,968,342 polygons in total). 1811 surfaces and 226 images.
- gordonrobb
Have you checked how many images you are using compared to the max of your cards?
Yes true, thanks gordonrobb ... there is a limit in the number of texture maps you can load in the GPUs, check it in the IPR window. In your system you can load only 144 RGB color textures, plus 68 grayscale textures.
Perhaps some of your textures could be used as grayscale ones, you only need to change the image type in the imageTexture node to float.
Oh I was not aware of a limit of images! I thought it was more along the lines of 'if you have the ram available'
I also do have instances in the scene as well. I will try both suggestions tonight when I get a chance. I'll let you know.
Thanks.
Thanks.
CPU: Intel I9-14900KF | Mobo: Asrock Z790 Tachi | Ram: 128gb | Storage: 64tb | GPU: 2x Asus ROG Strix - RTX3090 24gb
