Hi again all,
So I'm messing about (or trying) with Vertex Displacements.
I've got the nodes setup up correctly (I believe), but all that's happening is my object (subdivided plane) is getting move all as one, and not being displaced. Is there something 'special' I need to be doing to make it work?
Using LW 2015.3 btw.
TheMightySpud
Vertex Displacement
- TheMightySpud
I managed to get it working thanks, some weird issue with my displacement map.
Have to be honest, not impressed with 2020 so far. Rendering the same scene as I was in 4.05 and it's massively slower, that is if it renders at all. The amount of times I've gotten the 'render failure' message even with out of core turned on is getting silly, not to mention the amount of times it completely locks up lightwave.
- TheMightySpud
I haven't tried those yet if honest, I will give them a go though.
Thanks Juanjgon
Thanks Juanjgon
- TheMightySpud
Well, studio drivers are now installed........Octane now crashes as soon as I press f9 or open IPR.
Wonderful. :-/
Wonderful. :-/
Weird, here I have the Studio driver 451.77 and Octane seems to work fine. If you enable the log file in the plugin options panel, do you get any CUDA error on it? Do you know if Standalone 2020.1 works fine on this system?
- TheMightySpud
Sorry, I jump the gun on the last message, a couple of the surface names had Japanese or Chinese characters in them, renamed and it's now fine.
Ah, yes, sorry, this is an old known issue. Some characters in the material names can crash the plugin on the LightWave SDK side.TheMightySpud wrote:Sorry, I jump the gun on the last message, a couple of the surface names had Japanese or Chinese characters in them, renamed and it's now fine.
