Many pixels are not rendered in 4.00.0.137
Uhlhorn
Hi there,
I found an issue in Octane 4.00.0.137 for Modo. Many 2 by 2 pixels are not rendered in Octane:
Many 2 by 2 pixels are not rendered in Octane.
Here is the full size rendering with many holes:
Original rendering with holes.
Hi - can you try with the latest release please (4.01.1.138).
Hesekiel2517
Did you use adaptive Sampling? Try to increase the "min. sampling" to avoid errors in the noise estimation in very noisy scenes.
Uhlhorn
Hesekiel2517 wrote:Did you use adaptive Sampling?
Yes. And without adaptive sampling the issue does not appear, I just figured out.
Hesekiel2517 wrote:Try to increase the "min. sampling" to avoid errors in the noise estimation in very noisy scenes.
It does not solve all, it makes it better.
So I made some tests:
Minimum Samples: 512 Pixel Grouping: none
Minimum Samples: 512 Pixel Grouping: 2 x 2
Minimum Samples: 512 Pixel Grouping: 4 x 4
Minimum Samples: 2048 Pixel Grouping: none
Minimum Samples: 2048 Pixel Grouping: 2 x 2
Minimum Samples: 2048 Pixel Grouping: 4 x 4
No Adaptive Sampling
Return to “Foundry Modo”
