Octane 4 spectral denoiser
Rik56
Hi, I am testing the Octane 4 build, but I can't seem to get the spectral denoiser to work. I can't see any noticeable difference if it's on or off. Right now I activated the denoiser in the camera imager settings (the imager itself is enabled as well):
Am I missing something else?
Iceman9
You won’t see results in the render unless you select it among the various pass options. I am a c4d guy so I don’t know where you select that in Blender.
Rik56
ok I think I got it. You have to enable the render passes in Render Layer tab, specifcally the (Beauty?) Denoiser. Then go into node editor, switch to render compositing perspective and pull out the OctDenoiserBeauty. Here is a pic:
Return to “Blender”
