OctaneRender™ for Blender 2.24.2 - 9.6 Linux [OBSOLETE]
Locked
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • New 2.24.2 engine.
  • Improved the camera view to support the viewport shift.
  • Minor fixes and improvements...
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v9.6 Linux (100.0MB autoinstaller file)
DEMO is available..
Blender Octane Edition DEMO - v9.6 Linux (99.3MB autoinstaller file)
viewtopic.php?f=24&t=50498
Please, if you decided to report a bug:
- Don't post here the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
- If you like to discuss something about the plugin - create a separate thread, don't flood in these testing threads please.
Any meaningless or rebus-like "reports" here will be deleted, just to keep the testing threads clean - because these threads are directly used as the source for fixing and improving the plugin.
Synthercat
I've noticed that rotating the screen around while on render preview (shift + Z) is slower that doing it in windows... will that change in the future?
Do we know what's causing it? I am on Mint 17.2 with the normal kernel and 352.21 nvidia drivers
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
afecelis
Synthercat wrote:I've noticed that rotating the screen around while on render preview (shift + Z) is slower that doing it in windows... will that change in the future?
Same here. Mint 17.2, dual boot with Windows 10 pro X64.
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
Next version HERE.
Locked
Return to “Blender”
