What I'm doing wrong with export ??? :(
msciwiarski
Hi..
I have a tyre textured in blender...
Blender render shows it correctly:
This are the settings for the material in blender..
After export to Octane bump map looks like this:
Can anyone tell me what I'm doing wrong ??
I've tried both Octane exporters.. (for 2.55 and 2.56 Blender version)
thanks for reply..
Michal
Hardware: Core2Quad Q9650, Asus P5Q Deluxe, GeForce GTX580
Software: Windows 7 Ultimate x64, Sketchup 8, Blender 2.56, Octane 2.4
yoyoz
did you unwrap your UVs?
It seems that you're using default 'run-time' or 'self-generated' flat UV mapping in blender (no layer to which the UV applies, it should show 'UV' in the panel). You must explicitely set the UV mapping for proper export to Octane.
Yoyoz
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
msciwiarski
Hi..
Yes I've made it exactly according to this tutorial http://blenderartists.org/forum/showthr ... 717&page=1
yoyoz wrote:You must explicitely set the UV mapping for proper export to Octane
Could you clarify how should I do this ?? sorry, Im not a guru in blender :)
thanks for the reply..
Michal
yoyoz
I'm not a blender guru either, despite not-enough-popular rumor :-)
In your texture panel, the field named 'Layer' should show the UV map, ie the relationship between your mesh surface and a flat image. This doesn't come up automatically and without setting it up, even if Blender may does the right guess, you can't rely on it and must provide a proper one (from blender itself).
Here's a nice tutorial about UV mapping; http://www.blendercookie.com/2010/03/02 ... character/
(tuto shows what some people call nudity but that's just grey pixels)
Hope it helps,
Yoyoz
steveps3
Do you have 2 instances of the same mesh on top of each other?
(OS) Windows 7(64)
msciwiarski
steveps3 wrote:Do you have 2 instances of the same mesh on top of each other?
no I haven't.... but I've solved the problem.. I've made an export from blender by the blender exporter (without edges).. and it works now
I forgot, that OBJ file contains only geometry and UV mapping information, nothing more..
thanks...
Cheers
Michal.
Return to “Blender”
