Save path each time?
megacal
is there a way to have Blender save the path to the Octane project, project name, and
path to Octane.exe from one session to another?
Each time I open Blender and want to use Octane, it requires re-setting the paths.
Not critical, just annoying.
Do I have to dedicate one Blender to Octane, and keep it up all the time?
2 GPUs: Zotac GTX 580 1.5gb Amp! GPU for Octane....Galaxy 210 1gb for display
CPU: AMD Phenom II X4 955,3.2 ghz RAM: 8gb OS: Win7 64
grimm
Open blender and set up the paths as you want them. Then do a CTRL-u or select "Save user settings" under the file menu. That should keep track of the paths. Just make sure to un-check the "load UI" when you load up your .blend files so they don't overwrite your settings. Then just save them back out again so they have the correct settings too. Warning: this will mess up any custom UI setup you have made to those files.
Jason
megacal
Thanks Jason!
Got it. :)
Return to “Blender”
