Objects move quite differently after exporting from SU8
Forums: Objects move quite differently after exporting from SU8
Re: Objects move quite differently after exporting from SU8
Postby Jaberwocky » Tue Apr 26, 2011 3:59 pm
Jaberwocky Tue Apr 26, 2011 3:59 pm
yannic wrote:Hi Jaberwocky,
I have tried your test-scene and did some tries with my scene also. Now I understand what was wrong! It is not very easy for me to find the right point to click to get my camera moved as in your scene. BUT it is a giant step better than before. Now I can work with it! Thank you so much! Also many thanks to Tig as well.
By the way, may I ask you another question: I wonder why your example-room is "visible" inside although there is no light. I have tried a similar test-room-scene yesterday and recognized that behavior also although I did not have windows in my room. In other renderers it would be dark.
yannic
That's because it is rendered using direct lighting which will given a quick and dirty lighting solution.
Try the same scene in Pathtracing though without adding windows or linterior lights and you'd have a very dark scene. ;)
Jaberwocky
Postby yannic » Tue Apr 26, 2011 4:47 pm
yannic Tue Apr 26, 2011 4:47 pm
Oh, thank you! I see I have much to learn! :geek:
yannic
Previous
Return to SketchUp
Who is online
Sat Jan 25, 2020 7:42 am [ UTC ]
