Octane Render for SketchUp 3.03.3.2 Stable (obsolete)
Forums: Octane Render for SketchUp 3.03.3.2 Stable (obsolete)
Re: Octane Render for SketchUp 3.03.3.2 Stable Release
Postby visualmax » Sun Sep 25, 2016 2:14 pm
visualmax Sun Sep 25, 2016 2:14 pm
Hi.
There is a problem with scale.
Importing the model size = 1 * 1000
for example: try to export a cube 1000x1000x1000mm form sketchup, and then import it as proxy
fix it please.
visualmax
Postby haze » Sun Sep 25, 2016 8:06 pm
haze Sun Sep 25, 2016 8:06 pm
visualmax wrote:Hi.
fix it please.
Thanks for the report, we will fix this.
haze
Postby azen » Mon Sep 26, 2016 3:51 am
azen Mon Sep 26, 2016 3:51 am
visualmax wrote:Hi.
fix it please.
This is likely related to units of measurement. Sketchup uses the Imperial System by default, which can create issues when using metric units. We will make note of this as we explore the issue in greater detail.
azen
Postby visualmax » Tue Sep 27, 2016 7:06 pm
visualmax Tue Sep 27, 2016 7:06 pm
azen wrote:
visualmax wrote:Hi.
fix it please.
This is not related with units. If you do the same thing with inches. It will be the same result.
visualmax
Postby azen » Wed Sep 28, 2016 1:38 am
azen Wed Sep 28, 2016 1:38 am
visualmax wrote:
azen wrote:
visualmax wrote:Hi.
fix it please.
Thank you for the clarification. I will look further into this. I will try to zero in on this to get the fix in before the upcoming hot-fix release. At latest, it should be in the hot-fix release following that.
azen
Previous
Return to SketchUp
Who is online
Users browsing this forum: No registered users and 2 guests
Wed Nov 25, 2020 2:28 pm [ UTC ]
