OBRX export
Forums: OBRX export
OBRX export
Postby manos » Wed Aug 13, 2014 9:42 am
manos Wed Aug 13, 2014 9:42 am
Hello, i would like to ask more about the ORBX export... I'm trying to animate a scene.
Is there a way to use some kind of animation plugin and export that in octane standallone ?
I recently used the IO ready camera script but that's only for animating the camera's position ....
Thanks.
CPU: INTEL i7 3.40 GHz/RAM: 8 GB/GPU: 2XGTX690/OS: WIN 7 64 BIT/SKETCHUP 2014/OCTANE for SU
manos
Re: OBRX export
Postby resmas » Wed Aug 13, 2014 2:31 pm
resmas Wed Aug 13, 2014 2:31 pm
Hello mate, for what I know its not possible to export any kind of sketchup animation to Octane. As Octane StandAlone can only render animation via alembic file.
I belive its in the roadmap of Sketchup Plugin to render internal SU animation.
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
resmas
Re: OBRX export
Postby fuzzybro » Wed Aug 13, 2014 5:43 pm
fuzzybro Wed Aug 13, 2014 5:43 pm
I plan to add animation support between pages (scenes) but that is pretty much it.
For more advanced animations please use Octane Standalone.
Cheers
fuzzybro
OBRX export
Postby manos » Wed Aug 13, 2014 6:22 pm
manos Wed Aug 13, 2014 6:22 pm
Sorry I'm new in animation, and I don't understand what kind of files are necessary, I thought that .ORBX was the deal,(make your geometry, animate with some sort of SU plugin, use the OR for SU , open the viewport and then in the plugin menu export an ORBX file..use that OBRX in the standalone ver, render) ?..As I mentioned above I made a few test with the IO ready camera script ....it works like a charm but still it's only for camera's movement....
I don't mind using the standalone, but how is that possible with sketchup ?
Is there any compatible plugin for animating in SU ?
I don't know, there is a key frame plugin for sketchup but does it export alembic files ?
manos
Re: OBRX export
Postby fuzzybro » Thu Aug 14, 2014 6:00 pm
fuzzybro Thu Aug 14, 2014 6:00 pm
manos wrote:Sorry I'm new in animation, and I don't understand what kind of files are necessary, I thought that .ORBX was the deal,(make your geometry, animate with some sort of SU plugin, use the OR for SU , open the viewport and then in the plugin menu export an ORBX file..use that OBRX in the standalone ver, render) ?..As I mentioned above I made a few test with the IO ready camera script ....it works like a charm but still it's only for camera's movement....
Hi manos,
You can check Lua forums: viewforum.php?f=73
Not sure if there is a script to solve your problem. But you can always ask for help there.
Hope that helps,
Bro
fuzzybro
Return to SketchUp
Who is online
Users browsing this forum: No registered users and 3 guests
Thu Nov 26, 2020 1:41 am [ UTC ]
