Sandbox terrain
Forums: Sandbox terrain
Sandbox terrain
Postby neo83_gr » Fri Jun 27, 2014 6:18 pm
neo83_gr Fri Jun 27, 2014 6:18 pm
Hello, I was working at our great new plugin, but I had a problem when using the sandbox tools. It's not a problem of the plugin, I just try to solve it.
I made a new terrain and sculpted it. But when I used displacement on it, the triangles were separated as you can see on the image. Any ideas? I tested all the "octane mesh" properties (true-false-smoothing) and also the material's rounded edges.
neo83_gr
Re: Sandbox terrain
Postby fuzzybro » Sun Jun 29, 2014 6:05 pm
fuzzybro Sun Jun 29, 2014 6:05 pm
neo83_gr wrote:Hello, I was working at our great new plugin, but I had a problem when using the sandbox tools. It's not a problem of the plugin, I just try to solve it.
Hi neo83_gr,
Looks like the original mesh is not smoothed and each face is a separate mesh.
Try smoothing the surface in Sketchup (http://help.sketchup.com/en/article/114940)
If that won't help, could you please send me the scene?
Thank you
fuzzybro
Re: Sandbox terrain
Postby neo83_gr » Mon Jun 30, 2014 4:17 pm
neo83_gr Mon Jun 30, 2014 4:17 pm
Hello, I also tried what you proposed. As I said, the plugin is good , I just want to find a way to work around it.
Here is the very simple scene I made
https://dl.dropboxusercontent.com/u/6296546/terrain.skp
neo83_gr
Re: Sandbox terrain
Postby kavorka » Mon Jun 30, 2014 4:19 pm
kavorka Mon Jun 30, 2014 4:19 pm
i dont use the sketchup plugin, but for displacement, it will create those edges where you have UV seams. Maybe that is the problem?
kavorka
Re: Sandbox terrain
Postby neo83_gr » Mon Jun 30, 2014 4:47 pm
neo83_gr Mon Jun 30, 2014 4:47 pm
yes, that's why I think this problem is not of the plugin and it's unsolvable too. But I'd like to know if anyone has a way to do a displaced terrain
neo83_gr
Re: Sandbox terrain
Postby kavorka » Mon Jun 30, 2014 5:02 pm
kavorka Mon Jun 30, 2014 5:02 pm
If you unwrap you terrain with one solid UV (no seams) and use a tileable displacement texture, it should work.
kavorka
Re: Sandbox terrain
Postby neo83_gr » Tue Jul 01, 2014 8:46 am
neo83_gr Tue Jul 01, 2014 8:46 am
ok I actually did it! with thrupaint plugin. It works perfect now. Thnx a lot!
neo83_gr
Re: Sandbox terrain
Postby resmas » Wed Jul 02, 2014 10:53 am
resmas Wed Jul 02, 2014 10:53 am
kavorka wrote:If you unwrap you terrain with one solid UV (no seams) and use a tileable displacement texture, it should work.
was about to say the same. ;)
neo83_gr wrote:ok I actually did it! with thrupaint plugin. It works perfect now. Thnx a lot!
That looks really nice mate. Well done.
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
resmas
Re: Sandbox terrain
Postby Jorgensen » Sun Jul 06, 2014 11:39 am
Jorgensen Sun Jul 06, 2014 11:39 am
very nice done!
Jorgensen
Return to SketchUp
Sun Oct 25, 2020 6:05 am [ UTC ]
