Python command for "Convert Materials"?
Hurricane046
Hello!
We're quite often in a situation where we need to convert many Standard C4D Materials to Octane ones.
We've already made a script which will do a lot of steps for us such as optimizing the models or adding their materials into corresponding layers, but when it comes to automatically converting all the native C4D materials to Octane ones we are struggling to automate this step.
FULL SCRIPT HERE - It's for automatic setup of 3D exported World of Warcraft characters:
import c4d
from c4d import documents
# MOVE ALL POLYGON OBJECTS UP
def main():
    doc = documents.GetActiveDocument()
    # Find polygon objects
    objects = doc.GetObjects()
    for obj in objects:
        if obj.GetType() == c4d.Opolygon:
            obj.SetBit(c4d.BIT_ACTIVE)
        child = obj.GetDown()
        while child:
            if child.GetType() == c4d.Opolygon:
                child.SetBit(c4d.BIT_ACTIVE)
            child = child.GetNext()
    # Move up
    selected_objects = doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_CHILDREN)
    for obj in selected_objects:
        if obj.GetUp():
            obj.InsertBefore(doc.GetFirstObject())
            c4d.CallCommand(14039) # Optimize...
    # Deselect
        doc.SetSelection(obj, c4d.SELECTION_SUB)
    # Update UI
    c4d.EventAdd()
if __name__=='__main__':
    main()
# REMOVE ALL SUBDIVISION SURFACE OBJECTS
def main(keyword):
    doc = c4d.documents.GetActiveDocument()
    # Find Subdiv objects
    all_objects = doc.GetObjects()
    for obj in all_objects:
        if keyword.lower() in obj.GetName().lower():
           obj.Remove()
    # Update UI
    c4d.EventAdd()
if __name__ == '__main__':
    main("Subdivision")
# REMOVE LAST BONE OBJECT
def main():
        if "item" in obj.GetName().lower() and "rig" in obj.GetName().lower():
            obj.Remove()
    c4d.EventAdd()
    main()
# ROTATE CHARACTER BONE STRUCTURE UPWARDS
def main():
        if obj.GetType() == 1019362:
            doc.SetSelection(obj, c4d.SELECTION_ADD)
    selected_object = doc.GetActiveObject()
    current_rotation = selected_object.GetRelRot()
    new_rotation = c4d.Vector(current_rotation.x , current_rotation.y - 1.570795765, current_rotation.z)
    selected_object.SetRelRot(new_rotation)
    c4d.EventAdd()
    main()
# REMOVE SDS TAGS
import c4d
def main():
        tags = obj.GetTags()
        for tag in tags:
            if "SDS" in tag.GetName().upper():
                tag.Remove()
    c4d.EventAdd()
    main()
# ADD MATERIAL LAYER
def GetFirstLayer(doc):
    return doc.GetLayerObjectRoot().GetDown()
def main():
    project_path = doc.GetDocumentPath()
    path_components = project_path.split("\\")
    last_word_after_backslash = path_components[-1]
    print("{}".format(last_word_after_backslash))
    fl = GetFirstLayer(doc)
    name = last_word_after_backslash
    nl = c4d.documents.LayerObject()
    nl.SetName(name)
    if not fl:
        nl.InsertUnder(doc.GetLayerObjectRoot())
    else:
        nl.InsertAfter(fl)
    c4d.EventAdd()
    main()
# ADD MATERIALS INTO LAYER
def main():
  c4d.CallCommand(300001025) # Select All
  c4d.CallCommand(200000148, 299989000) # Layer
    main()
# DISABLE MATERIAL REFLECTANCE
import c4d
def main():
    materials = doc.GetMaterials()
    for material in materials:
        material[c4d.MATERIAL_USE_REFLECTION] = False
c4d.EventAdd()
    main()
