Fisheye alignment issue
- pandayoghurt
- Contact:
There seems to be an issue with the Fisheye lens in the universal camera. When you use Full frame for the fisheye type, what you see in the live viewer doesn't match the picture viewer. Seems like the camera is further out in the the picture viewer render.
							THREADRIPPER, 32GB RAM, 3080ti Win 10 64, C4D R2023.2.2, OCTANE 2023.1 BETA3 R4
						I've tried to reproduce it without luck. Are you sure you checked for user errors? Give us a scene if you're sure that's a plugin issuepandayoghurt wrote:There seems to be an issue with the Fisheye lens in the universal camera. When you use Full frame for the fisheye type, what you see in the live viewer doesn't match the picture viewer. Seems like the camera is further out in the the picture viewer render.
- pandayoghurt
- Contact:
Thanks for your help with this. I just can't figure it out:
https://www.dropbox.com/scl/fi/zh24gpfo ... 4hmc8&dl=0
						What's the different here? Colors or coverage of camera? It's looking exact same if you set LOCK res on LV and color spaces
- pandayoghurt
- Contact:
Thanks for getting back to me so quickly.
I've never used the lock resolution function before.
Why are the two renders different with Lock Res on and off?
How do I get the picture viewer render to match the live viewer with Lock res off?
thanks
thanks
						Different proportion on output will cause to see extra part of image. LOCKRES will guarantee to have same proportion even same resolution on default zoom level.pandayoghurt wrote:Thanks for getting back to me so quickly.
thanks
