What is the Light Direction pass for?
noisyboyuk
Hi!
I'm looking into doing some relighting in Nuke and needed a normal pass. I can see several normal passes (Geometry, Tangent, Smooth and Shading), 3 of which seem to give me very similar results.
However I did also notice that there is a Light Direction pass in the beauty passes but I searched the plugin and standalone manuals and found no info (the plugin manual only seems to cover a handful of the available passes).
Is this info actually in the manual or can I find it elsewhere?
calus
- geometric normal pass :
Normals in world space before any material smoothing and bump/normal map.
- smooth normal pass :
Normals in world space with the Material "smooth" applied but before bump/normal map.
- shading normal pass :
Normals in world space with the Material "smooth" and bump/normal map.
- tangent normal map :
Normals in local tangent space with bump/normal map
- Light direction pass :
Estimation of the dominant direction from where most of the light is coming. (I get this one from standalone tooltip)
Also if you don't use passes but a render in info channel kernel, take care to enable "bump and normal mapping" for the Shading normal channel and the tangent normal channel
Pascal ANDRE
ceen
is there somewhere a comprehensive guide on how to use all those special passes in compositing and for what? That would be interesting.
3080ti
