Bake Textures
JessicaVines
2 Things...
1) Is there anyway Octane can make use of Cinema's 3d procedural space. Everything seems to convert to UV space?
2) I often use c4d procedural noises gradients etc when texturing, but I am often bogged down quite a bit when it comes time to compile for render because I have to re-bake these textures again and again.
Is there a way to bake all textures used on selected materials to the tex folder and relink accordingly? Kind of like when I am ready to commit to final render and subsequent renders...
Maybe a smart solution would be to first make a copy of the material, replace all contained procedural textures with specified res baked textures inside specified texture folder (eg. at 2k, 4k etc) , then replace all instances of that material in object manager? Perhaps this is a feature request?
Thanks.
No. Octane run shaders on gpu. That's not possible to sample cpu shaders. Atm, plugin does pre-renders those for mapping as images. So it's losing 3d coordinate space in this way.
I'm not sure that understood well. In early versions, i was doing some save for rendered shaders to hdd and using this images. Due speed concern, i'm doing these transfers through ram. I suppose that you want to pre-render these and use as image, right? If so, this would not be a good way. It will cause more complexity for workflow. Better to wait for OSL system. It's intended to be in 3.0.
