Cinema 4D Prime and Octane Render
str9led
Is the version of Cinema 4D Prime (most stripped down version Cinema4d) can install the plug-Octane Render? I would like to purchase this program but I do not know whether it can be installed Octane Render. Iet my know, thanks!
Win 10 x64 |2xGTX1080 + 2xGTX780Ti + GTX680 4GB | Core I7 @ 3,75 | 32GB |Asus z77 | Cinema 4D | BMD Fusion | Octane Render
http://www.blendervisual.blogspot.com | MDS Animation Studio http://www.mdsanima.pl | The Waiter http://youtu.be/ykNyn30HgnA
Why don't you try demo version? I heard that's working.
str9led
I tried the demo, but the demo does not work octane render in each version, prime or studio too, so here I asked. I might add that another plugin worked on the demo.
try with Cinema 4D demo + plugin demo. I think there is a problem on your system/driver/etc... It shows that a problem if you can't work with demo versions. So you should update for example your drivers,etc.. Also you need R16.050, but 16.037 will not work.
str9led
I upgrade to R16.050 Demo version + octane demo, It working :) Thanks so much
