daylight simulation on an animated scene
Forums: daylight simulation on an animated scene
Autodesk Softimage XSI (Developed by Face)
Postby benoit_3d » Fri Oct 26, 2012 12:56 pm
benoit_3d Fri Oct 26, 2012 12:56 pm
Hello,
I would like to know if it's possible with the current exporter to render a daylight simulation (float3daylightsystem, from 3AM to 22PM) on an animated scene (trees and cars are runing) ? I try to export Sun Direction, but it seems to force me using float3 sky environment and it does not change anything though my light is animated.
Any idea how I can achieve this ?
Thank you,
benoit_3d
Re: daylight simulation on an animated scene
Postby face » Sat Oct 27, 2012 6:03 am
face Sat Oct 27, 2012 6:03 am
It should be possible.
Use the option "Export Sun Direction" under the "Export Configuration" tab.
face
http://vimeo.com/user2509578
face
Postby benoit_3d » Mon Oct 29, 2012 12:26 pm
benoit_3d Mon Oct 29, 2012 12:26 pm
Hello Face,
Thank You for your answer.
I test that, but it removes me my "float3daylightsystem" sttings to the "float3" daylight environement.
I found the light of float3 not as good as the float3daylightsystem.
Any idea ?
Kind Regards,
PS by the way, I forget to answer you on vimeo (http://vimeo.com/51596059#comment_8068426), but after deleting the setting 3.03 works !
benoit_3d
Postby face » Mon Oct 29, 2012 1:11 pm
face Mon Oct 29, 2012 1:11 pm
I haven´t any control of the node which is used for the daylight system.
The plugin only submits the sun position/direction via the commandline to the standalone.
face
face
Postby benoit_3d » Mon Oct 29, 2012 1:59 pm
benoit_3d Mon Oct 29, 2012 1:59 pm
OK, thx,
Octane switch to float3 even if float3daylightsystem was initially set in the ocs file.
Any tip to reduce export time (obj export/import) : I have an animation of 4000 frames, and export is longer than rendering :)
Kind Regards,
benoit_3d
Return to Autodesk Softimage XSI
Who is online
Wed May 22, 2024 9:50 pm [ UTC ]
