OctaneRender® for Maya® 2.24.2 - 7.20 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2013.5, 2014, 2015 and 2016 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
  • Implemented two different animated ORBX export modes:
    1. As a clean ORBX (the mode available previously). All geometry nodes will be accessible in standalone node editor after export. No vertex animation is exported (ORBX does not support vertex animation).
    2. Scene will be packed into Alembic node and exported inside ORBX. The vertex animation will be exported (using Alembic). No geometry nodes are visible/accessible in standalone node editor.
DOWNLOAD
OctaneRender for Maya 2.24.2 - 7.20 (12.5MB autoinstaller file)
OctaneRender for Maya 2.24.2 - 7.20 Demo (11.7MB autoinstaller file)
viewtopic.php?f=24&t=50498
Yours,
The OctaneRender™ Team.
As promised we got a new developer here to be dedicated to Maya plugin. This must speed up the Maya plugin development, 'cause I've been loaded by a lot of different projects and Maya development has slowed down as a consequence...
So, please meet k.a.schubert. ;)
Please don't expect the immediate development speed up, because k.a.schubert needs some time to dig into a plugin...
calus
same thing with this version, when i batch render openexr files , "_passes" is added at the end of the filenames.(image.001_passes.exr), making image sequences not usable...
Or is it a coincidence that my Maya just began this behavior when i installed the 7.19 and 7.20 plug-in ?
Pascal ANDRE
Jolbertoquini
Thanks for the quick update Jim, It's working now for me that's Great...
The layer ID for geometry type with the projection camera texture still doesn't work well I change the geometry type.
Also one thing... to passes to work I need name the cases at tab passes EXR channel names and if I have any of the cases named doesn't work.... :?:
So with other scenes doesn't work the passes if I'm not rename ...
Please, it's a amazing work guys but I think UI tab should look more like the standalone for the simple reason users will find easily they self when working with the standalone and the plug , Standalone have a great organisation on the tab and separate passes on sections...
as Beauty passes/ Post processing passes/Render layer passes/Lighting passes/Info passes and (Material passes for v03)
right now is a bit of mission of the way is range ... Why I'm so strict with that for me as a only use it's alright but for Us at company with more then 25 user on Maya and more standalone become a difficulty to make everyone understand without training then because option they supposed to be link or so far and not like standalone on the same place (specially for passes). I'm sorry if sounds annoying but is a pipeline issues for us.
Best
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
bluerocket
Thanks for the update!
Best Regards
Asus Rampage IV Extreme | i7-3930K | 32GB | 2x GTX TITAN | 2x GTX670 4Gb | Win 64x
Jolbertoquini
Hi Guys,
For the new Export options...Really great option for the export Alembic you save us a huge time of export and match with our workflow thumbs up guys excellent!!!! :o :D
Thanks a Lot
JO
Slimshader
JimStar wrote: So, please meet k.a.schubert. ;)
Hey nice to meet ya!
ruhi
Hey guys!
Is there anybody who knows "skip existing frames" problem solved? Big issue for batch renderers..
cea
ruhi wrote:Hey guys!
+1 :)
k.a.schubert
Nice to meet you too! :)
Locked
