OctaneRender® for Maya® 2.24.2 - 7.19 Win [OBSOLETE]
Locked
Maya® Version Requirements
This release will work with Maya® Versions 2013.5, 2014, 2015 and 2016 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
  • Fixed the "ncam" command line flag.
  • Added the EXR-resolution setting to Octane "Additional" tab (16-bit or 32-bit).
  • Added "Passes EXR channel names" tab to Octane settings. Needed to fine-tune for some applications expecting specific channel names in EXR for specific passes.
  • Added "Ignore frame sequence bounds" to motion blur settings. If set - the full frames span will not be required for each motion-blurred frame.
  • Fixed alembic export bug.
  • Fixed "Before" internal motion blur mode bug.
  • Minor fixes and improvements...
DOWNLOAD
OctaneRender for Maya 2.24.2 - 7.19 (12.5MB autoinstaller file)
OctaneRender for Maya 2.24.2 - 7.19 Demo (11.7MB autoinstaller file)
viewtopic.php?f=24&t=50498
Yours,
The OctaneRender™ Team.
As promised we got a new developer here to be dedicated to Maya plugin. This must speed up the Maya plugin development, 'cause I've been loaded by a lot of different projects and Maya development has slowed down as a consequence...
So, please meet k.a.schubert. ;)
Please don't expect the immediate development speed up, because k.a.schubert needs some time to dig into a plugin...
Jolbertoquini
JimStar wrote:As promised we got a new developer here to be dedicated to Maya plugin. This must speed up the Maya plugin development, 'cause I've been loaded by a lot of different projects and Maya development has slowed down as a consequence...
Great News Jim!
and thanks again for the updates, hope this will help you with all the hard job on Maya. :D I'm really help to hear that.
Also if you don't mind could you tell me a time or schedule for a alpha plug for Octane 3 please ?
I guess you Guys work on this one?
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Jolbertoquini
Hi Jim
Find one issue when camera mapped is activate and I activate the Id and change for layer pass the camera projection changes here the attach file.
...I'm not use so much that features but I was testing still not working well for me. Or maybe something setup in wrong way?
Of course if I do in the opposite way, that's mean change the default ID of the other but not of the mesh with projection is working..So the problem must come from geometry type with camera mapped activate on the textures.
aswell EXR passes for layer I have problems to render not copiled and doesn't render to I use maya 2014
Best
JO
Projections.rar
(191.8 KiB) Downloaded 338 times
Jolbertoquini
Hi Guys,
Really interesting features but doesn't seems to work as well the name are different layers reflection the case to rename the pass reflection channel???
Is missing organisation on the passes names would be good to have a tab layout organisation as the standalone (attach images)... in this version a lot bug to render one exr with passes included I will have a look on others Maya plug later night .
Please guys would be great to have this working well.
Best
JO
Tab layout
Tab layout
calus
with this version when batch rendering, "_passes" is added to the file name of the render ( example : image_0001_passes.exr ).
This is not nice to work with file sequence in post, file sequences are not recognized as file sequences anymore because of this...
Pascal ANDRE
Next version HERE.
Locked
