the projection of the light image on the wall ... the pictur
Goldisart
can not correctly adjust the projection of light ... anyone have any thoughts or help in this project... make the scene
more or less correctly if I place the ball to form a small image as in the projector and make the projection, then it works .... there is a more convenient option ?
test.rar
(855.17 KiB) Downloaded 317 times
Goldisart
I know one way ... but it is wrong need a huge image with a resolution of the sphere so it turns out ... I would like to know more simple way
test2.rar
(156.47 KiB) Downloaded 345 times
Goldisart
test 3
a variant of the projection light through the glass but it involves two objects 1 and 2 glass light source -
test3.rar
(160.97 KiB) Downloaded 334 times
paride4331
Hi Goldisart,
Could you kindly show me what is your goal?
Could you share a reference, an example; I understand you can not, but I do not understand what.
Goldisart
make an ordinary projector of static images and the video on the wall
Terryvfx
Maybe this can help you out I had this problem before, check this out
viewtopic.php?f=30&t=56820&p=291583#p291583
Goldisart
I raised this question because in 3D max is not working . Or I don't understand how to do it or the map is projected incorrectly prospects
paride4331
Hi Goldisart,
I attached a scene with the projected texture.
I hope it is what you needed.
project.zip
(1.16 MiB) Downloaded 394 times
Goldisart
thank you very much
darkline
Paride could you save this as a max 2014 file? I'm still struggling with image projector lights and would appreciate the help
thanks
Windows 7 64bit/ Intel 3930K/ ASUS Rampage IV/ GTX980ti x 2/ 64GB system RAM
Return to “Autodesk 3Ds Max”
