System: MBPro, Macosx 10.6.3, 2.26ghz intel core2 duo, 4gb ram, NO cuda versions installed before.
Came here when I saw a tweet from a friend. I followed the instructions to the letter ( using all the links that are provided - read the important readme. It is important. ) but it was saying that the renderer couldnt start because it was missing usr/local/cuda/lib/libcuda.dylib
A search on nividia forums revealed that the latest cuda toolkit does not include this dylib. A further search showed that previous to cuda version 2.3 it did. Apparently the dylib has been added to the "cuda drivers" which i was unable to find for macosx.
So this forum post is for people who are having this problem. go to the nvidia cuda section and download the 2.2 as well as the 3.0 version. note that the 3.0 version will delete the 2.2 so your choice is install 3.0 then install 2.2 or go with the 2.2 version.
Then run the octane render and the splash screen comes up so does the UI and you can get started.
The link below is the post that got me onto the track for a cuda version that actually does have this missing dylib. I am assuming that if you install the 2.2 then copy the libcuda.dylib to a safe place and then install 3.0 then copy the dylib back this might work ( have not tried ) .
http://forums.nvidia.com/lofiversion/in ... 02904.html
Please delete this post if I got something wrong. Just couldnt find anything for someone relatively new to cuda.
Off to play with octane.
