I have to post it here since I cant post in tutorial section anymore.
oldSelection = selection as array
setObjParams = false
for f = (startFrame = 0f) to (endFrame = 5f) by (frameStep = 1f) do (
sliderTime = f
for i = 1 to oldSelection.count do (
o = oldSelection
select o
outName = ("C:\\Users\\name\\Desktop\\test\\" + o.name + "_" + f as string + ".obj")
if (not setObjParams) then (
exportFile outName selectedOnly:true
setObjParams = true
else ( exportFile outName #noPrompt selectedOnly:true )
) -- obj loop
) -- anim loop
select oldSelection
fire this one up and export sequences, dont need to bake trajectory.
2 notes for people who doesnt know alot about scripting.
you need to modify the script 2 places.
first place :
change 0f and 5f to your selected place on time line, the template exports frame 0-5..should be logic
second place :
Change url to your own, remember \\ instead of a single \ to define paths..
-mads
3dsmax script to batch export animation v0.1a
updated :
Now it exports the entire scene, as long as its selected before you run script..
before it grabed all objects independantly.
sliderTime = f
outName = ("C:\\Users\\stuff\\Desktop\\test\\" + "_" + f as string + ".obj")
setObjParams = true
) -- anim loop
sliderTime = f
setObjParams = true
) -- anim loop
Amiga 1000 with 2mb memory card
thanks,
i'll be adding flags to automate octane partly to do stuff like this,
so you might want to update it and post it again with those new auto start options, after 2.1 is released.
Radiance
Radiance
i recommend you wait till we have released 2.2.franklau wrote:hi first of all gk thank you for provide the batch export script, but i have a question can you please explain the procedure to render through the batch or i have to do it individually.
it will come with easy to use scripts/plugins for max, no scripting required.
Radiance
