OctaneRender™ Standalone 2.24.2
abstrax
Hi all,
This is another small release providing some bug fixes that have accumulated over the last weeks.
Changes since version 2.24.1:
  • Sped up authentication during start up.
  • IES files can now be selected for the RGB image texture node.
  • Fixed launch of slaves via daemon on Linux.
  • Fixed a deadlock in batch rendering of certain scenes.
  • Frames of the batch render script match now exactly the frames of the time slider.
Downloads:
Windows
- 64-bit commercial version (installer)
- 64-bit commercial version (ZIP archive)
- 64-bit demo version (installer)
- 64-bit demo version (ZIP archive)
Mac OS X
- 64-bit commercial version (DMG image)
- 64-bit demo version (DMG image)
Linux
Happy rendering,
Your OTOY NZ Team
Rikk The Gaijin
I was hoping to see 2.25, with the infamous ORC support.
How long do we have to wait? :(
gabrielefx
do the ies lights work as texture projectors now?
kavorka
do you no longer need to all have the same version when networking?
It used to be that it would say "invalid version" if one of the computers wasnt updated or running the latest daemon. Now it works if they are different versions. Not sure if you planned that.
Goldisart
Thinking out loud. Question : is it possible to make the beam of light had a finite value in its length. And hasn't spread. The perimeter that we chose.
immortalartscom
hey goldisart, there is a parameter called GI clamp and pathterm power in rendersettings. i think this is what you mean?
and THX OTOY for update!!!
immortal-arts | filmproduction | soundstudio
http://www.immortal-arts.com
abstrax
kavorka wrote:do you no longer need to all have the same version when networking?
No, that requirement still exists. It was an oversight on my side: I forgot to update the internal version number (it's still 2240001)... Since there are no changes on the data structures that make it not work with old 2.24.1 masters, I won't change the archives. Let me know if you run into any issues.
Goldisart
I would like to see the function of light distribution in the light sources
roeland
gabrielefx wrote:do the ies lights work as texture projectors now?
You can add an image to the "Distribution" input. Set the "Projection" type to "perspective" and the "Border Mode" to "Black color".
The projector by default is pointed along the Z axis and it has a projection angle of 90°.
You can aim the projector to different directions by either transforming the instance or by putting a rotation in the "Plane transformation" input.
Changing the UV transform scale will change the projection angle and aspect ratio.
Roeland
Micha
Please fix the noise generator, there is a visible repeating pattern. Could be great to get it with the next build, since I need a nice brush effect for a commercial project soon. ;)
viewtopic.php?f=23&t=50012
http://www.simulacrum.de - Visualization for Designer and Architects
Win7 64 | Dual Xeon E5-2687W | 32GB RAM | 2 GTX 780 6GB | Rhino3D
