GTX 590??
universalpenman
Just wondering if some body tried already EVGA GFORCE GTX 590 with 3Gigs, I'm thinking on buy it but I' still having some doubts about the performance with octane :S
plz anybody reading this topic share any info about the GTX 590 thanks!! :)
matej
I haven't seen any reliable confirmations that this card would work as expected (wold work at all + all 3GB available to Octane) - so I would be cautious and wait with the purchase.
cgmo.net
abstrax
The 3GB will be split into two, since the two separate GPUs will have their own memory each. I.e. you will be able to use only 1.5GB of VRAM.
Marcus
Jaberwocky
I agree with Abstrax.More than likely 1.5Gb per GPU.This card is very cost effective though.£580 for 1024 Cuda Cores as opposed to £800 for 2 standard 580's.The only thing is less memory for large scenes that the Palit 3GB 580 cards.However 2 of them would be in the region of £860.Also the 590 is useful if you only have 1 PCIE x 16 slot in your motherboard.You could theoretically have one GPU running display and one running Octane using just the one slot.The downside less memory than 3GB models for large scenes also make sure you have a good power supply to feed the beast and good case airflow.
Timmaigh
universalpenman wrote:Just wondering if some body tried already EVGA GFORCE GTX 590 with 3Gigs, I'm thinking on buy it but I' still having some doubts about the performance with octane :S
see my topic in the OffTopic section of the boards, i just bought it
Intel Core i7 980x @ 3,78GHz - Gigabyte X58A UD7 rev 1.0 - 24GB DDR3 RAM - Gainward GTX590 3GB @ 700/1400/3900 Mhz- 2x Intel X25-M G2 80GB SSD - WD Caviar Black 2TB - WD Caviar Green 2TB - Fractal Design Define R2 - Win7 64bit - Octane 2.57
universalpenman
abstrax wrote:The 3GB will be split into two, since the two separate GPUs will have their own memory each. I.e. you will be able to use only 1.5GB of VRAM.
Marcus
Thanks for that info Marcus, I' dont have much expertise with GPU's but you may can tell me something about the zotac 590 with 3G in a single core? I just found it in newegg, and in the zotac site you can find both of them, the one with twin GPU and the one with 3G in single GPU
Thanks again Dude!! ;)
universalpenman
Marcus
OOOps!! I ' had a little misunderstanding with the cards :oops: the one with 3G in single GPU is the 580, I' just check it!
Thanks anyway fellas!! :)
