here is the data: the led shape is cicles with 4mm diameter.60 led cycles per meter give 200lumens. how should I set the led material
regards, joseph
you want to simulate the photometric distribution or the light effect only?joseph wrote:Hi , I want to simulate the light of a led strip, but I don't know how to set my material, so if anyone more experienced could help?
here is the data: the led shape is cicles with 4mm diameter.60 led cycles per meter give 200lumens. how should I set the led material![]()
regards, joseph
Octane doesn't handle exact luminous power: candles, lumens, watts, etc.joseph wrote:thank you gabrielefx
what I want is to aply a blackbody emision material to each 4mm diameter disc so that 60 of them will give aprox 200 lumens!
my concern is the power of the light. could somedy tell me what values to use?
