ratshole
Hi, plugins for sequoia c4doctane 2024.1 not released ? Updated to sequoia doesn't work :(
mitchino
Over on the Redshift forum the M4 Max is hitting the same benchmark as a laptop 4090. Definitely catching up!
ratshole wrote:Hi, plugins for sequoia c4doctane 2024.1 not released ? Updated to sequoia doesn't work :(
You can find it here:
viewtopic.php?f=85&t=84012
For a correct installation of c4doctane 2024.1 plugin, firstly you need to update your Maxon C4D to a recent build, (R25.117, R26.107, 2023.2, 2024.4, 2025.0.1), or plugin cannot be correctly loaded, please visit your MyMaxon page and download the update.
ciao,
Beppe
cjadams
Is there any update for multi gpu (network rendering) for Modo 17 on mac Apple silicon?
I noticed its only prime.. and the network button doesn’t do anything. I was running C4D and had everything setup … but now with Modo .. are we really stuck only in really old version and in prime?
cjadams wrote:Is there any update for multi gpu (network rendering) for Modo 17 on mac Apple silicon?
the Prime version is not an issue, but Network Rendering has been added only from 2024.1 version, so you need a Modo Prima 2024.1 version to be able to have Net Render in macOS.
Try to ask in the Modo section of this forum about that specific version.
viewforum.php?f=34
ciao,
Beppe
ratshole
ciao,
Beppe
about this screenshot:
It seems that plugin is not installed correctly and probably something is missing from the original folder!
Please download it again, then uncompress it in the plugins folder, then remove only the .xlib files not related to your Maxon C4D version.
It should be like this in C4D 2025:
ciao,
Beppe
Hi all,
new Standalone 2025.1 Beta1 is now available also for macOS:
https://render.otoy.com/downloads/000_o ... _macos.dmg
Here you can find the list of the new features:
viewtopic.php?f=33&t=84310
Happy Mac GPU rendering!
ciao,
Beppe
trogers
Not sure if this is possible yet as it seems like a feature on the cutting edge, but is it possible and or is there any plan to support using an iPad Pro M4 as an additional render GPU when using a Mac? I have a MacBook Pro and would love to be able to speed up renders by plugging in my iPad to use as an additional GPU.
Win 11 / AMD 3970x / Nvidia 4090 + 2080 Ti / 128GB
pegot
I would like to know this too. But more for setting up scenes on the iPad and using Network Rendering to render them to other Macs and / or Windows machines as Network Slaves (is that headless rendering?).
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
