4.26 Huge performance/fps drop
Forums: 4.26 Huge performance/fps drop
Unreal® Engine Integrated Plugin
Moderator: ChrisHekman
Postby joshuamkerr » Tue Oct 26, 2021 1:10 pm
joshuamkerr Tue Oct 26, 2021 1:10 pm
I've just started using OctaneRender in Unreal Engine (currently in 4.26)
I am noticing is a distinct slowdown when activating the Octane plugin. The scene is fairly light, it has a few building meshes and roads, plus a few lights. Without Octant activated the scene runs at it's 120fps limit. I'm using a 3080 GPU.
...but once octane is loaded I'm down to 8fps and if I add a few more meshes it completely freezes the viewport.
Would anybody be able to point me toward some optimisations/ things I can try that will bring back performance? I'm hoping to build some large worlds for panoramic shots but can't see myself getting close if this is normal behaviour.
joshuamkerr
Re: 4.26 Huge performance/fps drop
Postby ChrisHekman » Tue Oct 26, 2021 2:32 pm
ChrisHekman Tue Oct 26, 2021 2:32 pm
Would it be possible for you to send me the scene you are using?
And are you using the latest version of the plugin?
ChrisHekman
Postby joshuamkerr » Wed Nov 03, 2021 12:31 pm
joshuamkerr Wed Nov 03, 2021 12:31 pm
Hi Chris, It seems that a fresh install of the plugin solved the issue.
All working fine now.
joshuamkerr
Postby ChrisHekman » Wed Nov 03, 2021 2:21 pm
ChrisHekman Wed Nov 03, 2021 2:21 pm
joshuamkerr wrote:Hi Chris, It seems that a fresh install of the plugin solved the issue.
Great to hear :)
ChrisHekman
Return to Unreal® Engine
Fri May 17, 2024 6:55 am [ UTC ]
